December 22, 2024 5:22 pm
Author Topic: BARN FIND!!!!  (Read 73177 times)
Re: BARN FIND!!!!
« Reply #135 on: March 31, 2011 5:31 am »
Sure does not look like a barn find any more. Are you showing at all this "spring"?
Interior's done!
« Reply #136 on: March 31, 2011 1:52 pm »
No. There are a few things to do to the outside yet and next up is to tear out the rear end and put in 3.25 gears. That's a pretty big task on the '35. I got lucky on ebay again and got a brand new, in the box set of 3.25s for $286 shipped. I want to finish up the rest so it will cruise this summer.
« Last Edit: March 31, 2011 1:55 pm by JakesBackyard »
Re: BARN FIND!!!!
« Reply #137 on: April 05, 2011 1:42 am »
very cool
Bullnose
« Reply #138 on: April 10, 2011 12:59 am »
Made it today.
Re: BARN FIND!!!!
« Reply #139 on: April 26, 2011 3:42 am »
I'm thinking the torque tube enclosed driveshaft rearend was not one of Henry's brightest ideas. What a pain in the ass to get out of the car! And I'm planning on it being a bigger pain to get it back in. I've got it all apart now and will clean it up before putting in the new 3.25 gears. Everything looks good except one bearing and it just has a little chip in one roller. Wish it was back together for a little cruising in this nice weather.
Re: BARN FIND!!!!
« Reply #140 on: April 26, 2011 1:10 pm »
Are you going to buy that special rear end lube??
Re: BARN FIND!!!!
« Reply #141 on: April 26, 2011 1:51 pm »
Man, that's a loaded question...
I'm not sure what to use in the rear for lube.  Looks like a lot of people use the newer synthetic. It's some heavy stuff and now that I have it apart I can see why.  It lubes all the rear end bearings except the outters on the axles.
Re: BARN FIND!!!!
« Reply #142 on: April 26, 2011 2:59 pm »
Tom we use the term "gear lube" around here....... :)
Re: BARN FIND!!!!
« Reply #143 on: April 26, 2011 3:55 pm »
I just read a few weeks ago that Ford had a special heavy lube that is available from some of antique stores. I used 80-90 in the RPU and it very slowly seeps out around the bell gaskets. Not a big deal as it easy to get at to clean off. Don't think I would use synthetic.
Yes the out side bearing needed to be greased. One of the reasons you have a hard time finding good outside bearings and races is that people didn't grease them.
Re: BARN FIND!!!!
« Reply #144 on: April 26, 2011 6:53 pm »
heh heh heh, you said rear end lube, heh heh heh
Re: BARN FIND!!!!
« Reply #145 on: April 27, 2011 5:51 am »
I happen to have 2 or 3 quarts of the heavy stuff from Early Ford or wherever. Its the stock weight stuff. 150w? Need some Jake?
Re: BARN FIND!!!!
« Reply #146 on: April 27, 2011 12:26 pm »
lol
Re: BARN FIND!!!!
« Reply #147 on: April 27, 2011 1:25 pm »
fleet Farm has 85- 140 which works pretty well in old machinery and other leaky stuff
Re: BARN FIND!!!!
« Reply #148 on: April 27, 2011 1:42 pm »
Now that it's all broke down, I need three bearings. Mac's is about the best deal. So I'll order some of the 600W that's supposed to go in it from them as well. That must be some thick shit.  I wonder if you have to spoon it in...
Re: BARN FIND!!!!
« Reply #149 on: April 27, 2011 5:44 pm »
Jake dose `35 have the  pinon bearing on the end inside by the ring gear?? I can't remember what year they started that.
