My torch handle is a Pureox (sp?) and I use a #2 tip for 18 and 20 gauge sheet metal. I see Pureox is not listed on the chart you have posted. Let me check tonight, I'll use a tip cleaner and mic it. That should get me close.
Gas welding is not rocket science, Pete was getting the hang of it. Set for neutral flame, have a small enough tip for the job. If you have too big tip opening and try to choke it back with a low flame it will pop back and blow a hole in the puddle. But the metal joint tight. Most of the stuff I did on Joel car this weekend had gaps and had to fill with rod, it doesn't make for a very good looking weld. Move the tip in a circular monition and back out for a second if you think you’re going to lose your puddle.
