April 16, 2025 11:30 am
Author Topic: Parts have arrived! and some air ride questions.  (Read 20357 times)
« Reply #30 on: January 03, 2006 10:08 pm »
bags are for groceries ;)  but then again i'm cheep
« Reply #31 on: January 03, 2006 10:24 pm »
Your not cheap...your inexpensive. :albino:
« Reply #32 on: August 06, 2006 6:27 am »
Serious........do you like the chop on this one?
http://www.jalopyjournal.com/forum/showthread.php?t=119338
« Reply #33 on: August 06, 2006 6:27 pm »
i lilke it
« Reply #34 on: August 06, 2006 9:38 pm »
Yes, SLant the B Pillars and thats pretty Close.  maybe a little lower.  but that is damn near right on.
« Reply #35 on: August 15, 2006 9:56 pm »
When you bringin it home?
« Reply #36 on: November 04, 2006 9:09 pm »
Bumping this up wondering if you ever got the front bagged yet?
« Reply #37 on: November 05, 2006 8:04 am »
Not yet...   I dont have the car here, nothings been done since last Xmas on the 49...   plans have changed.  Im gonna notch the rear and make it lay frame..
so some things need to be changed.
I need dropped spidles for the front too.
~Aaron
« Reply #38 on: November 07, 2006 11:59 pm »
Laying frame may not be so cool if you have a system failure at 75 on the interstate.  I would highly recommend bump stops to give some clearance.  Trust me, it is also not cool to hit a pothole in the middle of the Ponderosa parking lot at 5 miles per hour.
« Reply #39 on: November 08, 2006 1:02 am »
well, Figurtively....    i dont think with where my Front crossmember is installed it will be able to without some serious modifacation...
i just want it REALLY REALLY low.   there will be a bump stop in it.
« Reply #40 on: November 08, 2006 6:07 pm »
Easy removable bumpstops.  something that you can remove when you're cruising, but in place on the highway.
« Reply #41 on: November 08, 2006 6:27 pm »
If you MUST lay frame I would use blocks that can be bolted to the frame and then replaced as they wear out.
Loading...
